[mapguide-trac] #1345: set build configurations to explicity target
x86
trac_mapguide at osgeo.org
Tue May 4 03:35:27 EDT 2010
#1345: set build configurations to explicity target x86
Reporter: jng | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: Maestro-2.1
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
The current Maestro build configuration is AnyCPU. On an x64 system AnyCPU
will target x64 and as a result this makes MapGuideDotNetApi.dll unusable
because it is a 32-bit wrapper around 32-bit unmanaged binaries.
The fix is to explicitly target x86 as the CPU for all Maestro project
files.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1345>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
