[mapguide-trac] #1351: CreateSession can generate invalid
session ids
trac_mapguide at osgeo.org
Fri May 7 07:56:43 EDT 2010
#1351: CreateSession can generate invalid session ids
Reporter: jng | Owner:
Type: defect | Status: new
Priority: low | Milestone:
Component: Map Agent | Version: 2.2.0
Severity: trivial | Resolution:
Keywords: | External_id:
Old description:
> The recent security patches for the AJAX viewer imposed the following
> pattern restriction on MapGuide session ids:
> 00000000-0000-0000-0000-000000000000_aa_00000000000000000000
> The "aa" component is the locale when the CREATESESSION mapagent call is
> made. However if a custom LOCALE parameter is passed which is not 2
> characters (eg. en-US), then that is actually incorporated into the
> generated session id itself, making it unusable when it is passed to the
> AJAX viewer.
> Attached is a modified mapagent form for the CREATESESSION operation.
> Steps to reproduce:
> 1. Load the modified form
> 2. Specify a LOCALE greater than 2 characters (eg. en-US)
> 3. Invoke the CREATESESSION operation
> 4. Open any WebLayout using this generated session id
> 5. You will get a http authentication prompt because the generated id
> fails the pattern check.
> The LOCALE parameter should either be rejected or validated to ensure it
> is 2 characters wide.
New description:
AJAX viewer.
Steps to reproduce:
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1351#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
