[mapguide-trac] #1363: OGR Provider fails to select polygon correctly when using a layer filter.
MapGuide Open Source trac_mapguide at osgeo.org
Fri May 21 09:21:11 EDT 2010
   Reporter:  bgugeograf  |       Owner:
       Type:  defect      |      Status:  new
   Priority:  medium      |   Milestone:
  Component:  General     |     Version:  2.1.0
   Severity:  minor       |    Keywords:
External_id:              |
 I am running mapguide 2010 with OGR Provider version 3.4.0.
 My problem is that I am able to select a polygon by clicking outside the
 polygon. It is like it has a boundary box outside the object which selects
 the polygon when clicked.
 I only get the error when I have defined a filter on layer.
 If I remove the filter, then I am able to select the polygon like
 expected. I also tested the same data with sql and it worked fine. I have
 tried OGR provider version 3.4.0 og 3.4.1.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1363>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
