[mapguide-trac] #1365: Logon window OK button
trac_mapguide at osgeo.org
Mon May 24 17:52:31 EDT 2010
Reporter: pcardinal | Owner: jng
Type: defect | Status: new
Priority: low | Milestone:
Component: Maestro | Version: 2.1.0
Severity: trivial | Keywords: OK button Logon
External_id: |
The OK button is enable in the Logon window when it appears. If you select
the Connect via TCP/IP radio button, then the OK button is disable and
immediatly after if you select the Connect via HTTP radio button, then the
OK button is still disable : the OK button should be enable at this step.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1365>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
