[mapguide-trac] #1519: Updating grid interpolation files in
Transformation definition unsupported.
trac_mapguide at osgeo.org
Mon Nov 8 13:25:37 EST 2010
#1519: Updating grid interpolation files in Transformation definition unsupported.
Reporter: NormOlsen | Owner: NormOlsen
Type: defect | Status: closed
Priority: medium | Milestone: 2.3
Component: General | Version: 2.1.0
Severity: major | Resolution: fixed
Keywords: Geodetic Transformations | External_id: 1354463
Changes (by NormOlsen):
* status: new => closed
* resolution: => fixed
Comment:
Corrected witrh revision #5377
The protection system embedded in the CoordinateSystem? Dictionary
facility
(templatized) was adjusted to allow users to modify distribution and user
protected transformation definitions.
An extra parameter has been added to the standard dictionary template
functions
which enables the calling module to turn off protection. These template
functions are only used internal to the API. No changes to the exposed
API.
Restriction of editing only the grid interpolation file names, directions,
and
order thereof is accomplished inside of CS-MAP. Thus, for all
transformations
other than those of the Grid Interpolation type remains in effect within
the
MapGuide CoordinateSystem API.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1519#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
