[mapguide-trac] #1281: Path corrections and small template extensions in mapviewerphp/layerdefinitionfactory.php
MapGuide Open Source trac_mapguide at osgeo.org
Tue Nov 9 18:13:34 EST 2010
   Reporter:  gabrimonfa   |       Owner:  brucedechant
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:  2.3
  Component:  General      |     Version:  2.1.0
   Severity:  trivial      |    Keywords:
External_id:               |
Comment(by brucedechant):
 The changes look good. However, the createlayer.php file will also need to
 be updated to work with these changes.
 Also, I would like to change the order of parameters from what you had:
 static function CreateLineRule($legendLabel, $filter, $strokeThickness,
 $color)
 To:
 static function CreateLineRule($legendLabel, $filter, $color,
 $strokeThickness)
 This way the new parameter is on the end.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1281#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
