[mapguide-trac] #1521: Use mouse wheel to zoom map in the
"Digitize" process
trac_mapguide at osgeo.org
Fri Nov 12 03:43:59 EST 2010
#1521: Use mouse wheel to zoom map in the "Digitize" process
Reporter: wuma | Owner: Mars Wu
Type: enhancement | Status: new
Priority: low | Milestone:
Component: AJAX Viewer | Version: 2.2.0
Severity: minor | Keywords:
External_id: 1309956 |
When it is in "Digitize Polygon" or "Digitize LineString" process, there
is no way to zoom in the map. Sometimes to digitize a precise shape, it's
necessary to zoom in so that the vertex of the polygon could be digitized
as precise as possible.
This patch implements it this way:
1. Add a ScaleFeedback method for the digitizers. E.g.
PolygonDigitizer.ScaleFeedback = function(scale, origin)
for (var i = 0; i < this.xs.length; ++i)
var x = this.xs[i];
this.xs[i] = origin.X + (scale * (x - origin.X));
var y = this.ys[i];
this.ys[i] = origin.Y + (scale * (y - origin.Y));
this.Feedback(origin.X, origin.Y);
2. Modify GotoView function in Ajaxmappane.templ to scale the digitize
feedbacks when the view is changed.
function GotoView(x,y,scale,tohistory,moveovimg)
scale = finscale? GetNearestFiniteScale(scale): NormalizeScale(scale);
var zoom;
if(zoom = (scale != curScale))
HideMapImage();
requestTiles = true;
// Update the digitize feedback
if (digitizing)
if (typeof digitizer.ScaleFeedback != "undefined")
digitizer.ScaleFeedback(curScale / scale,
new Point(wheelZoomCursor.X, wheelZoomCursor.Y));
else
Above change can handle the zoom change. The digitize feedbacks will be
changed after the zoom has finished. The reason why we don't provide a
"instant" scale feedback (the digitize feedbacks will be updated according
to every single mouse wheel change) is because redrawing the digitize
feedbacks needs regenerating hundreds of <div> elements which is very CPU
consuming.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1521>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
