[mapguide-trac] #1522: Small extensions to the templates viewerfiles/arearule.templ and viewerfiles/linerule.templ
MapGuide Open Source trac_mapguide at osgeo.org
Fri Nov 12 12:17:57 EST 2010
   Reporter:  gabrimonfa   |       Owner:
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:
  Component:  General      |     Version:  2.2.0
   Severity:  trivial      |    Keywords:
External_id:               |
 Some properties are parameterized in these templates while others are
 simply hardcoded.
 The idea is to extend the two templates to be more parametric
 In particular, thickness and color of the stroke in the arearule
 http://trac.osgeo.org/mapguide/attachment/ticket/1281/arearule.templ.diff
 and thickness of the linerule
 http://trac.osgeo.org/mapguide/attachment/ticket/1281/linerule.templ.diff
 In order for this to work also the function calling the templates should
 be modified accordingly.
 For php the function is mapviewerphp/layerdefinitionfactory.php
 The needed modifications are in the diff file attached
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1522>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
