[mapguide-trac] #1529: Coordinate System API does not allow
creating a so called "Standalone" geodetic transformation as
supported by CsMap
trac_mapguide at osgeo.org
Thu Nov 18 13:28:58 EST 2010
#1529: Coordinate System API does not allow creating a so called "Standalone"
geodetic transformation as supported by CsMap
Reporter: baertelchen | Owner: baertelchen
Type: defect | Status: new
Priority: low | Milestone: 2.3
Component: General | Version: 2.1.0
Severity: minor | Keywords: Coordinate System API
External_id: |
Currently, only geodetic transformations can be created that require an
API client to specify transformation parameters - incl. grid files.
However, it does not allow for creating such transformations that are
built into CsMap: namely WGS72(to WGS84 as published by the DMA) and the
NULL transformation (which does nothing but only allows to switch from one
datum to another).
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1529>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
