[mapguide-trac] #1476: mgserver lock up using GDAL Plugins (mrsid)
trac_mapguide at osgeo.org
Mon Nov 22 13:15:45 EST 2010
Reporter: andrewd | Owner: trevorwekel
Type: defect | Status: new
Priority: high | Milestone:
Component: Server | Version: 2.2.0
Severity: critical | Keywords:
External_id: |
Comment(by trevorwekel):
I think we have discovered the problem. I did some checking on Visual
Studio .Net 2003 and Microsoft dropped support for it on Windows Vista.
They strongly suggest moving to Visual Studio 2005
http://msdn.microsoft.com/en-us/vstudio/aa948854.aspx.
This leads me to believe that using Visual Studio 2003 dlls on any
operating system newer than Vista is a dangerous approach since the
compiler that uses those dlls is "not supported". I think it is
reasonable to assume that VS 2003 dlls will not work under WOW64. I
seriously doubt that Microsoft has tested it.
What does this mean for the GDAL plugins? Basically, we need to compile
all the plug in libraries with Visual Studio 2008. This will include the
SDKs from ERDAS and LizardTech. The compilation work will also be
required to resolve threading issues. Most of the thread checking tools
expect the same system and c-runtime allocators to be used throughout the
application.
This could be a lot of work if no one has started on it. Hopefully ERDAS
and LizardTech have VS 2008 SDKs available.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1476#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
