[mapguide-trac] #1533: [WFS] Feature count returned less than
values of MaxFeatures
trac_mapguide at osgeo.org
Tue Nov 23 05:02:45 EST 2010
#1533: [WFS] Feature count returned less than values of MaxFeatures
Reporter: liuar | Owner: liuar
Type: defect | Status: new
Priority: low | Milestone:
Component: WFS Interface | Version: 2.2.0
Severity: trivial | Keywords:
External_id: 1361400 |
Comment(by liuar):
Two factors could result in this issue:
1.
Because the !MgServerFdoFeatureReader in !MapGudie server uses -1 to mark
empty, while !MgWfsFeatures in !MapGuide web tier uses 0, so there will be
1 more feature returned from !MapGuide server. So I updated the
maxFeatures value from numFeaturesToRetrieve to numFeaturesToRetrieve-1
Ptr<MgByteReader> resultReader =
featureService->GetWfsFeature(featureSourceId, ((sSchemaHash.size()==0) ?
sClass : sSchemaHash + _(":") + sClass), requiredProperties,
m_getFeatureParams->GetSrs(), filter, numFeaturesToRetrieve-1, sVersion,
sOutputFormat, sSortCriteria, sPrefix, oFeatureTypes.GetNamespaceUrl());
[[BR]]
2.
Read schema namespaces will cause m_iMaxFeatures-- which will cause the
last feature lost from the response gml document, so I add
m_iMaxFeatures's value while reading schema namespaces.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1533#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
