[mapguide-trac] #1539: Script error when closing IE window / tab with the Quick Plot preview dialog open in Ajax viewer
MapGuide Open Source trac_mapguide at osgeo.org
Fri Nov 26 00:26:09 EST 2010
   Reporter:  wuma     |       Owner:  Mars Wu
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  General  |     Version:  2.2.0
   Severity:  trivial  |    Keywords:
External_id:  1367734  |
 In Ajax Viewer, if we close the IE browser's window or tab while the Quick
 Plot preview dialog is still open, there will be a script error.
 It happens only in IE with compressed jxlib.js. The reason is,
 quickplotpanel page has a unloade event handler which will close the
 preview dialog. The event handler invokes the PreviewDialog.cancel() to
 close the dialog. While cancel() just "fades out" the dialog to have a
 good visual effect. In IE, the web page will be closed before the "fade
 out" process finishes, then an error will occur.
 The solution is: don't use "fade out" effect. Instead, just completely
 remove the Jx.Dialog element from mapFrame. A method
 PreviewDialog.dispose() is implemented to do this.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1539>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
