[mapguide-trac] #1428: GETMAPLEGENDIMAGE should omit empty
layer groups from being rendered
trac_mapguide at osgeo.org
Tue Sep 7 13:12:56 EDT 2010
#1428: GETMAPLEGENDIMAGE should omit empty layer groups from being rendered
Reporter: jng | Owner:
Type: enhancement | Status: new
Priority: medium | Milestone:
Component: Rendering Service | Version:
Severity: trivial | Keywords: legend, rendering
External_id: |
Changes (by tomfukushima):
* cc: brucedechant (added)
Comment:
The code in the patch looks like it will work, but should we be concerned
about efficiency? For example, if there are 20 groups and 800 layers in
the map then that loop will execute the statement "layer->!IsVisible() &&
layer->!GetGroup() == mggroup.p" 20 x 800 = 16,000 times. Should we
instead do something like the following...
define Hashtable of groups
for each layer
if isVisible & !groups.Contains(layer.groupName)
add the group name to the Hashtable
for each group
if groups.Contains(group.name)
execute the code to add group
Now, assuming the hashtable has a good implementation, this might be
substantially faster.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1428#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
