[mapguide-trac] #1368: ACE:init missing in MapGuideCommon lib
trac_mapguide at osgeo.org
Fri Sep 10 17:57:50 EDT 2010
Reporter: haris | Owner: brucedechant
Type: defect | Status: new
Priority: low | Milestone:
Component: General | Version: 2.2.0
Severity: trivial | Keywords:
External_id: |
Comment(by brucedechant):
This is from the Init_ACE.h file:
namespace ACE
* This class implements the functions for the initialization and
* shutting down ACE. These functions are called only once per ACE
* invokation.
* @return Returns 0 on success, -1 on failure, and 1 if it had already
been
* called.
extern ACE_Export int init (void);
From the above we should only be calling ACE::init() once. I did a quick
test that called it from inside MapGuideCommon and the server would crash
when I tried to shut it down. So I don't think calling it multiple times
is a good idea.
What about moving the ACE::init() from the server/web main executables to
MapGuideCommon?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1368#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
