[mapguide-trac] #1441: "Properties available in viewer" not being saved
MapGuide Open Source trac_mapguide at osgeo.org
Fri Sep 17 13:27:54 EDT 2010
   Reporter:  andrewd  |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  medium   |   Milestone:
  Component:  Maestro  |     Version:  2.1.0
   Severity:  minor    |    Keywords:
External_id:           |
 Using v2.1.2.5125 - I've got a layer with 3 properties. If I make any
 changes to the "Properties available in viewer" section regarding the
 visibility, my changes do not get saved. For example, by default, nothing
 is selected. If I select one of the 3 items, and save, my layer still
 shows no properties in the pane (when viewed from my layout).
 I seem to be able to get it to save by checking "all" (using the single
 button to select all). My layer then shows all items....but then if I want
 to turn some off, again, my changes do not get saved. The only way I can
 get it to work is by editing the xml manually.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1441>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
