[mapguide-trac] #1442: SHP Load procedure not working for long file names
MapGuide Open Source trac_mapguide at osgeo.org
Fri Sep 17 15:38:32 EDT 2010
   Reporter:  andrewd  |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  medium   |   Milestone:
  Component:  Maestro  |     Version:  2.1.0
   Severity:  minor    |    Keywords:
External_id:           |
 If you try to load a shp file with a very long name (like
 "021o04_5_0_VE_1240009_2" - which is a name from a Canadian Government
 group of layers, the resulting layer will have the wrong FeatureName. In
 this example, the resulting FeatureName is "-x30-21o04_5_0_VE_1240009_2".
 This makes the layer not work...if you then go into the layer and simply
 re-pick the schema, and then resave, it will work.
 For some reason, the load procedure is truncating the first part of the
 schema. This problem does not happen for other files with shorter names.
 This is using v2.1.2.5125.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1442>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
