[mapguide-trac] #1437: Memory leak in java webtier
trac_mapguide at osgeo.org
Fri Sep 17 19:42:34 EDT 2010
Reporter: andymorf | Owner: trevorwekel
Type: defect | Status: new
Priority: high | Milestone: 2.2
Component: Web API | Version: 2.2.0
Severity: critical | Keywords: java webtier
External_id: |
Changes (by trevorwekel):
* owner: => trevorwekel
Comment:
Does the attached testmem.jsp script show the leak? It should run if
dumped in www/mapviewerjava and accessed using
http://server/mapguide/mapviewerjava/testmem.jsp.
If it does not show the leak, can you provide a different test script
which does?
Also, which platform are you running (Windows, Linux, 32bit, 64bit...)?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1437#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
