[mapguide-trac] #1443: MgProxyFeatureService::GetCapabilities is using a fixed api version 1.0.0
MapGuide Open Source trac_mapguide at osgeo.org
Mon Sep 20 12:37:44 EDT 2010
   Reporter:  wuma      |       Owner:  Mars Wu
       Type:  defect    |      Status:  new
   Priority:  high      |   Milestone:
  Component:  General   |     Version:  2.1.0
   Severity:  critical  |    Keywords:
External_id:  1342879   |
Changes (by brucedechant):
 * cc: brucedechant (added)
Old description:
> Steps:
> - Run WebTier tests:Feature/GetCapabilities. It will get the capabilites
> for a certain FDO provider.
> - Keep the initial values for the test page except for changing the
> version to be 2.0.0
> - Submit the request
> You will find the response is always for 1.0.0 instead of 2.0.0.
> The reaons is like following:
> MgByteReader* MgProxyFeatureService::GetCapabilities(CREFSTRING
> providerName, CREFSTRING connectionString)
>     MgCommand cmd;
>     cmd.ExecuteCommand(m_connProp,                                  //
> Connection
>                        MgCommand::knObject,                         //
> Return type expected
>                        MgFeatureServiceOpId::GetCapabilities_Id,    //
> Command Code
>                        2,                                           // No
> of arguments
>                        Feature_Service,                             //
> Service Id
>                        BUILD_VERSION(1,0,0),                        //
> Operation version
>                        MgCommand::knString, &providerName,          //
> Argument#1
>                        MgCommand::knString, &connectionString,      //
> Argument#2
>                        MgCommand::knNone);                          //
> End of argument
>     SetWarning(cmd.GetWarningObject());
>     return (MgByteReader*)cmd.GetReturnValue().val.m_obj;
> The version is a fixed one: BUILD_VERSION(1,0,0) instead of the requested
> version
New description:
 Steps:
 - Run !WebTier tests:Feature/GetCapabilities. It will get the capabilites
 version to be 2.0.0
 The reasons is like following:
     MgCommand cmd;
 Connection
 Command Code
                        2,                                           // No
 of arguments
                        Feature_Service,                             //
 Service Id
 Operation version
 Argument#1
 Argument#2
                        MgCommand::knNone);                          // End
 of argument
 version.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1443#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
