[mapguide-trac] #1450: Enhance the GetWfsFeature API to support
customized namespaceUrl and namespacePrefix
trac_mapguide at osgeo.org
Thu Sep 30 09:29:21 EDT 2010
#1450: Enhance the GetWfsFeature API to support customized namespaceUrl and
namespacePrefix
Reporter: liuar | Owner: liuar
Type: enhancement | Status: new
Priority: low | Milestone:
Component: Feature Service | Version: 2.2.0
Severity: minor | Keywords: WFS GetWfsFeature
External_id: |
In order to pass the OGC CITE test, MapGuide need to have its
GetWfsFeature API extended to support user defined namespaceUrl and
namespacePrefix.
Two more parameters added in the the new interface: namespacePrefix and
namespaceUrl
/// \brief
/// Retrieves feature information based on the supplied criteria with
specified format.
/// <!-- Syntax in .Net, Java, and PHP -->
/// \htmlinclude DotNetSyntaxTop.html
/// virtual MgByteReader GetWfsFeature(MgResourceIdentifier
featureSourceId, string featureClass, MgStringCollection
requiredProperties, string srs, string filter, int maxFeatures, string
wfsVersion, string outputFormat, string sortCriteria, string
namespacePrefix, string namespaceUrl);
/// \htmlinclude SyntaxBottom.html
/// \htmlinclude JavaSyntaxTop.html
/// \htmlinclude PHPSyntaxTop.html
/// \param featureSourceId (MgResourceIdentifier)
/// The resource identifier defining the
/// location of the feature source in
/// the repository.
/// \param featureClass (String/string)
/// The feature class containing the features to retrieve.
/// \param requiredProperties (MgStringCollection)
/// The collection of properties to retrieve for each feature. If the
/// collection is null or empty, all properties will be retrieved.
/// \param srs (String/string)
/// The spatial reference system in which to return feature geometries
/// \param filter (String/string)
/// An XML string containing the definition for an OGC filter
/// \param maxFeatures (int)
/// The maximum number of features to retrieve. If the value is less
/// than or equal to zero, all features will be retrieved.
/// \param wfsVersion (String/string)
/// A string identifying the wfs version
/// \param outputFormat (String/string)
/// A string identifying the output format of
/// the retrieved feature information.
/// The supported values of output format are specified in OpenGIS Web
Feature Service (WFS) Implementation Specification - section 9.2
/// http://portal.opengeospatial.org/files/?artifact_id=8339
/// \param sortCriteria (String/string)
/// A string identifying the sort criteria
/// \param namespacePrefix (String/string)
/// A string identifying the namespace prefix in the output xml
/// \param namespaceUrl (String/string)
/// A string idenyifying the namespace url in the output xml
/// \return
/// Returns an MgByteReader containing the requested feature
information.
/// \exception MgInvalidArgumentException
virtual MgByteReader* GetWfsFeature(MgResourceIdentifier*
featureSourceId, CREFSTRING featureClass,
MgStringCollection* requiredProperties, CREFSTRING srs, CREFSTRING
filter, INT32 maxFeatures,CREFSTRING wfsVersion, CREFSTRING outputFormat,
CREFSTRING sortCriteria, CREFSTRING namespacePrefix, CREFSTRING
namespaceUrl) = 0;
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1450>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
