[mapguide-trac] #1651: Layer Definition editor defects and
loose ends
trac_mapguide at osgeo.org
Wed Apr 6 10:05:58 EDT 2011
#1651: Layer Definition editor defects and loose ends
Reporter: jng | Owner: jng
Type: defect | Status: new
Priority: medium | Milestone: Maestro-3.0
Component: Maestro | Version: 2.1.0
Severity: major | Keywords:
External_id: |
Description changed by jng:
Old description:
> The following defects were observed in the Layer Definition editor for
> Maestro 3.0 b3
> * Deleting a vector scale range does not update the underlying XML
> content
> * Adding a new vector scale range (control) does not create a default
> (line/point/area) rule controls
> * When generating a layer preview, the extents should be modified to fit
> into the visible scale ranges
> * When a particular point style is enabled (The Show XXX style checkbox
> is ticked), only create a new default rule if the current style has no
> rules in it
New description:
Maestro 3.0 b3
* ~~Deleting a vector scale range does not update the underlying XML
content~~
* ~~Adding a new vector scale range (control) does not create a default
(line/point/area) rule controls~~
* ~~When a particular point style is enabled (The Show XXX style checkbox
rules in it~~
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1651#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
