[mapguide-trac] #1656: The Bind() method of all top-level resource editor controls must support being called multiple times
MapGuide Open Source trac_mapguide at osgeo.org
Fri Apr 8 06:01:21 EDT 2011
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-3.0
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 When saving edits from the XML editor, it calls the Bind() method of of
 parent resource editor to re-initialize itself with the latest XML
 content.
 Unfortunately, most implementations of Bind() currently assume they will
 be called only once. These implementations need to be modified to allow
 being called multiple times.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1656>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
