[mapguide-trac] #1666: Maestro 3 - XML Mode Toolbar Validation
Fails
trac_mapguide at osgeo.org
Fri Apr 15 10:18:33 EDT 2011
#1666: Maestro 3 - XML Mode Toolbar Validation Fails
Reporter: crispinatime | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: Maestro-3.0
Component: Maestro | Version:
Severity: minor | Keywords:
External_id: |
Comment(by jng):
Ok I get that warning as well. I don't know why that happens at the
moment, but it definitely has no negative impact on the XML validation.
Just to prove the point, change the ResourceId element in that Layer
Definition XML to ResourceId'''s'''
Validate, and you'll see that it has correctly detected an unknown
ResourceIds element, which means it has correctly found and loaded the
LayerDefinition-1.3.0.xsd
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1666#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
