[mapguide-trac] #1672: Validate command on toolbar should be validating resource of active editor
MapGuide Open Source trac_mapguide at osgeo.org
Tue Apr 26 08:16:02 EDT 2011
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-3.0
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 In an oversight that was not apparent until now, the validate command on
 the toolbar does not actually validate the resource of the active editor
 (as some, including myself would've believed). The current command is
 actually the same validate context menu command, meaning it will validate
 the selected items on the Site Explorer.
 A separate validate command should be defined that does this validation
 and the existing toolbar command should be replaced with this one.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1672>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
