[mapguide-trac] #1766: Permance improvement: remove IsNull check
when get property from feature source
trac_mapguide at osgeo.org
Mon Aug 1 03:40:01 EDT 2011
#1766: Permance improvement: remove IsNull check when get property from feature
source
Reporter: hubu | Owner: hubu
Type: enhancement | Status: new
Priority: low | Milestone: 2.3
Component: Feature Service | Version: 2.2.0
Severity: trivial | Keywords: performance
External_id: |
IsNull check has some overhead, especially when the feature source connect
to database such as Oracle, SQL Server, and etc.
The solution is, catch all exceptions, if the property is indeed null, we
will rethrow an MgNullPropertyValueException.
The benifit for this solution is, we don't need to do IsNull check when
get properties only if the properties is indeed null.
The test results show that this solution can decrease the query featue
time about 3-5%. The test data is based on Oracle datasets, including 100
layers.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1766>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
