[mapguide-trac] #1477: ODBC dataconnection (MS Access) problem
MapGuide Open Source trac_mapguide at osgeo.org
Fri Dec 2 10:48:35 EST 2011
   Reporter:  andrewd  |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  high     |   Milestone:  Maestro-3.5
  Component:  Maestro  |     Version:
   Severity:  major    |    Keywords:
External_id:           |
Comment(by andrewd):
 I can't seem to run that version...If I extract the zip and run
 maestro.exe, I get an error and crash.
 System.NullReferenceException: Object reference not set to an instance of
 an object.
    at Maestro.Base.Services.ServiceRegistry.GetService[T]() in
 D:\Workspace\maestro-trunk\Maestro.Base\Services\ServiceRegistry.cs:line
 43
    at Maestro.Base.ZonedContainer.OnLoad(EventArgs e) in D:\Workspace
 \maestro-trunk\Maestro.Base\ZonedContainer.cs:line 68
    at System.Windows.Forms.UserControl.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.OnVisibleChanged(EventArgs e)
    at System.Windows.Forms.ScrollableControl.OnVisibleChanged(EventArgs e)
    at System.Windows.Forms.Control.OnParentVisibleChanged(EventArgs e)
    at System.Windows.Forms.Form.OnVisibleChanged(EventArgs e)
    at System.Windows.Forms.Control.SetVisibleCore(Boolean value)
    at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
    at System.Windows.Forms.Control.set_Visible(Boolean value)
    at
 System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32
 reason, ApplicationContext context)
    at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32
    at System.Windows.Forms.Application.Run(Form mainForm)
    at Maestro.Program.Main() in D:\Workspace\maestro-
 trunk\Maestro\Program.cs:line 141
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1477#comment:20>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
