[mapguide-trac] #1879: Maestro API - Fail to Create RuntimeMap
trac_mapguide at osgeo.org
Mon Dec 5 07:32:43 EST 2011
Reporter: crispinatime | Owner: jng
Type: defect | Status: new
Priority: medium | Milestone: Maestro-4.0
Component: Maestro | Version:
Severity: major | Keywords: Maestro API
External_id: |
A change in the Maestro API sometime in the last few weeks now results in
an exception being thrown when creating a runtime map.
I rolled back some Maestro API DLLs that I had built and my app runs again
- hopefully there is enough in the stack trace to see what the issue is.
It looks to be layer-dependent as on my test data in the office it does
not occur, only on a complex site with many data connection types (SHP,
SDF, ODBC) including joins and base layers.
The build that caused the err below was from Friday 3 December.
Exception Details: System.NullReferenceException: Object reference not set
to an instance of an object.
Source Error:
Line 248:
Line 249: RuntimeMap rtMap = mpSvc.CreateMap(md);
Line 250:
Source File: e:\Projects\-blah-\mapFrame.aspx.cs Line: 249
Stack Trace:
[NullReferenceException: Object reference not set to an instance of an
object.]
OSGeo.MapGuide.MaestroAPI.Mapping.RuntimeMapLayer.InitIdentityProperties(IVectorLayerDefinition
vl) +110
OSGeo.MapGuide.MaestroAPI.Mapping.RuntimeMapLayer..ctor(RuntimeMap
parent, ILayerDefinition ldf) +169
parent, IBaseMapLayer source, ILayerDefinition ldf) +60
OSGeo.MapGuide.MaestroAPI.Mapping.RuntimeMap..ctor(IMapDefinition mdf,
Double metersPerUnit) +570
OSGeo.MapGuide.MaestroAPI.PlatformConnectionBase.CreateMap(String
runtimeMapResourceId, IMapDefinition mdf, Double metersPerUnit) +38
runtimeMapResourceId, IMapDefinition mdf) +63
OSGeo.MapGuide.MaestroAPI.PlatformConnectionBase.CreateMap(IMapDefinition
mdf) +95
OSGeo.MapGuide.MaestroAPI.HttpServerConnection.OSGeo.MapGuide.MaestroAPI.Services.IMappingService.CreateMap(IMapDefinition
) +5
_Default.Page_Load(Object sender, EventArgs e) in
e:\Projects\-blah-\mapFrame.aspx.cs:249
System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o,
Object t, EventArgs e) +14
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender,
EventArgs e) +35
System.Web.UI.Control.OnLoad(EventArgs e) +99
System.Web.UI.Control.LoadRecursive() +50
System.Web.UI.Page.ProcessRequestMain(Boolean
includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1879>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
