[mapguide-trac] #1881: Maestro failes to run a profile on MapServer 2012
MapGuide Open Source trac_mapguide at osgeo.org
Tue Dec 6 07:58:17 EST 2011
   Reporter:  hm       |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:  Maestro 4 RC1
External_id:           |
 I have setup a simple ODBC FeatureSource that connects to a an MS SQL
 Server table with  about 100 rows with coordinates. I've added a single
 layer to a map.
 Using Maestro 4 RC1 (9298) running the Profile on the map, it fails.
 Server: Autodesk Infrastructure MapServer 2012 build 2.3.4202. Output:
 Profiling MapDefinition:
 Session:8b26a014-2005-11e1-8000-080027cb642a_en_7F0000010B060B050B04//17ec8685-5db2-4a8a-b186-0c3c30f020a3.MapDefinition
 Profiling LayerDefinition:
 Library://Byggesag/ByggesagLayer.LayerDefinition
 Identity fetching (ms): 0,5001
 Runtime layer creation (ms): 3458,4391
 Time to render scale range [0 : 10000000] (ms):  152,0193
 Rendering scales (ms): 4646,09
 Failed while profiling Layer Definition:
 ============= ERROR DETAILS ==========
 System.Exception: The remote server returned an error: (559)
 MgInvalidStreamHeaderException.:
 Invalid stream header exception.
 ---> System.Net.WebException: The remote server returned an error: (559)
    at System.Net.HttpWebRequest.GetResponse()
    at OSGeo.MapGuide.MaestroAPI.HttpServerConnection.DownloadData(String
 req) in
 C:\Maestro\OSGeo.MapGuide.MaestroAPI.Http\HttpServerConnection.cs:line
 1162
    --- End of inner exception stack trace ---
 req) in
 1182
    at
 OSGeo.MapGuide.MaestroAPI.HttpServerConnection.RenderRuntimeMap(String
 resourceId, Double x, Double y, Double scale, Int32 width, Int32 height,
 Int32 dpi, String format, Boolean clip) in
 C:\Maestro\OSGeo.MapGuide.MaestroAPI.Http\HttpServerConnection.cs:line 923
    at
 OSGeo.MapGuide.MaestroAPI.MgServerConnectionBase.RenderRuntimeMap(String
 Int32 dpi) in
 C:\Maestro\OSGeo.MapGuide.MaestroAPI\MgServerConnectionBase.cs:line 210
    at
 Maestro.Base.UI.ProfilingDialog.ProfileLayerDefinition(ILayerDefinition
 ldef) in C:\Maestro\Maestro.Base\UI\ProfilingDialog.cs:line 228
    at Maestro.Base.UI.ProfilingDialog.ProfileMapDefinition(IMapDefinition
 mapDef) in C:\Maestro\Maestro.Base\UI\ProfilingDialog.cs:line 274
 ======== END ERROR DETAILS =============
 Total for runtime Map Generation (ms): 9832,7486
 Runtime map generation in one go (ms):562,0714
 Full map rendering (ms): 260,5331
 Failed while profiling MapDefinition rendering:
 req) in
 1162
 req) in
 1182
    at
    at
 Int32 dpi) in
 mapDef) in C:\Maestro\Maestro.Base\UI\ProfilingDialog.cs:line 349
 *** Done ***
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1881>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
