[mapguide-trac] #1883: Fusion Editor: Add tooltip toggle to default layout
MapGuide Open Source trac_mapguide at osgeo.org
Thu Dec 8 11:12:58 EST 2011
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-4.0
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 When creating a new Flexible Layout, if the site version >= 2.4 a tooltip
 toggle widget needs to be added to the default layout.
 This is because the Maptips widget is now a UI widget, and must be present
 in the main toolbar or tooltips will not work as this widget is required
 to toggle it on/off
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1883>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
