[mapguide-trac] #1886: Maestro API - Can't Open (to Edit) Runtime
Map with Base Layers
trac_mapguide at osgeo.org
Mon Dec 12 11:11:17 EST 2011
#1886: Maestro API - Can't Open (to Edit) Runtime Map with Base Layers
Reporter: crispinatime | Owner: jng
Type: defect | Status: new
Priority: high | Milestone: Maestro-4.0
Component: Maestro | Version: 2.1.0
Severity: major | Keywords:
External_id: |
When re-opening a previously saved RuntimeMap containing Base Layers there
is an iterator across RuntimeMapLayers that always tries to set a
.Visible. Unfortunately this property is designed to throw an exception
for base layers and the internal calls need to be safer.
I added an:
if (this.Type != kbaseMap)
around three instances of setting the visibility in "RuntimeMapLayer.cs"
at/around lines 146, 722 and 764.
There may be a better way of handling this.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1886>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
