[mapguide-trac] #1887: QuickPlot + MapGuide 2.3 (SVN)
MapGuide Open Source trac_mapguide at osgeo.org
Tue Dec 13 12:20:57 EST 2011
   Reporter:  wrees        |       Owner:
       Type:  defect       |      Status:  new
   Priority:  low          |   Milestone:  2.3
  Component:  AJAX Viewer  |     Version:
   Severity:  major        |    Keywords:  quickplot exceed settings defined by administrator mapguide 2.3
External_id:               |
 I've been trying to get the new quickplot feature working in MapGuide 2.3
 SVN.  I kept running into the dreaded:
 The application resources required to generate the plot exceed the
 settings defined by the administrator
 I checked to make sure that PHP was compiled with gd, etc and everything
 was fine on that end.  I'm using the php viewer, and after a bunch of
 digging I found the culprit.
 Line 119 of mapviewerphp/quickplotgeneratepicture.php
         $tempImage = sys_get_temp_dir() . uniqid();
 this makes $tempImage as "/tmp4ee7858739161" causing it to fail to create
 the file.
 A better solution would be to use tempnam() in conjunction with
 sys_get_temp_dir.
 Line 119 of mapviewerphp/quickplotgeneratepicture.php turns into:
         $tempImage = tempnam(sys_get_temp_dir, "mgo");
 Can you please add this fix to the SVN trunk.
 Thanks!
 Warren
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1887>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
