[mapguide-trac] #1890: Maestro layer validation incorrectly report
a warning about composite style mixed with other styles
trac_mapguide at osgeo.org
Thu Dec 15 11:36:35 EST 2011
#1890: Maestro layer validation incorrectly report a warning about composite style
Reporter: gabrimonfa | Owner: jng
Type: defect | Status: new
Priority: low | Milestone:
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
When validating a layer (version 1.3.0) Maestro issues the following
warning
"The scale range 0 to 15001 contains a composite style defined alongside a
area/point/line style. The composite style takes precedence in such cases
meaning the area/point/line style is always ignored"
The layer does not have any composite style, but only an AreaTypeStyle.
The same happens also for layers with LineTypeStyle or PointTypeStyles.
I've attached the xml of the layer
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1890>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
