[mapguide-trac] #1891: Maestro sometimes marks layer as modified
immediately on opening
trac_mapguide at osgeo.org
Thu Dec 15 11:52:59 EST 2011
#1891: Maestro sometimes marks layer as modified immediately on opening
Reporter: gabrimonfa | Owner: jng
Type: defect | Status: new
Priority: low | Milestone:
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
Maestro SVN revision 6339
Sometimes, when opening a layer in gui view Maestro immediately marks the
layer as modified even if no modification was made.
Comparing the XML obtained saving the layer with the one that its version
before opening it, the difference is usually an empty XML node that the
gui added.
For instance in a 1.3.0 layer without any filter, the gui has added the
empty tag <Filter />.
The fact that the layer is immediately marked as modified may lead the
user to think that there was something incorrect in the previous version
of the XML or that something unusual has happened.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1891>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
