[mapguide-trac] #1893: Maestro - Improve AJAX Create Custom Command
Experience
trac_mapguide at osgeo.org
Mon Dec 19 11:02:24 EST 2011
#1893: Maestro - Improve AJAX Create Custom Command Experience
Reporter: crispinatime | Owner: jng
Type: enhancement | Status: new
Priority: low | Milestone: Maestro-4.0
Component: Maestro | Version:
Severity: minor | Keywords:
External_id: |
With the latest v4 Maestro, creating a custom command is a bit of an issue
When clicking "Add" -> "Invoke Script" in the custom commands a new blank
entry is created but at the bottom of the list with no default visibility.
Here the gridview should set the selected item to the new, last item so
the full UI to edit the command is exposed.
Secondly the new command is created with a blank name (OK) but even after
editing, when actually going to add the command to, say, the context menu
the blank name is still used. You need to save the .WebLayout, close the
tab and then re-open it again to be able to insert the custom command with
the right name
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1893>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
