[mapguide-trac] #1894: ServerDescribeSchema miss extension class if
it's not in the first schema
trac_mapguide at osgeo.org
Tue Dec 20 02:16:23 EST 2011
#1894: ServerDescribeSchema miss extension class if it's not in the first schema
Reporter: ChristineBao | Owner: Christine Bao
Type: defect | Status: new
Priority: medium | Milestone:
Component: Server | Version: 2.2.0
Severity: major | Keywords:
External_id: 1383979.01 |
Report from Autodesk QA:[[BR]]
1. Connect to one Oracle provider, assuming it has the following
schema:[[BR]]
SchemaA[[BR]]
FeatureClassA1[[BR]]
FeatureClassA2[[BR]]
SchemaB[[BR]]
FeatureClassB1[[BR]]
2. Connect to one SDF provider.[[BR]]
3. Create a join in Oracle connection, set primary class to be
SchemaB:FeatureClassB1[[BR]]
4. Execute GetClasses in Oracle connection, the extension join class
SchemaB:FeatureClassB1Extend does not show.[[BR]]
5. If create join in the first schema of Oracle, for example
SchemaA:FeatureClass1Extend, the extension class will show in GetClasses
command.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1894>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
