[mapguide-trac] #1897: Extended layer validation
trac_mapguide at osgeo.org
Wed Dec 21 05:25:19 EST 2011
Reporter: gabrimonfa | Owner: jng
Type: enhancement | Status: new
Priority: low | Milestone:
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
Maestri 4.0.0.6282
It would be useful if layer validation could check that no nonexistent
attribute is referenced in <Filter>, <Url> or <ToolTip>.
This may happen when layer are copied around or db schema is modified and
leads to FDO_81_IDENTIFIER_NOT_FOUND error (without any indication of the
affected layer and attribute, so difficult to find) and/or unexpected
results.
If fetching layer schema during validation is considered too heavy, we may
think of an "extended validation" to be done only on current layer
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1897>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
