[mapguide-trac] #1898: Maestro: invalid property mapping should be cleared when saving a layer in normal view
MapGuide Open Source trac_mapguide at osgeo.org
Wed Dec 21 05:37:43 EST 2011
normal view
   Reporter:  gabrimonfa  |       Owner:  jng
       Type:  defect      |      Status:  new
   Priority:  low         |   Milestone:
  Component:  Maestro     |     Version:  2.1.0
   Severity:  trivial     |    Keywords:
External_id:              |
 Maestro 4.0.0.6282
 Suppose that a layer (A) is cloned to another one (B) that has similar
 stilization.
 Moreover, suppose that the layer A use some <PropertyMapping> that are not
 valid for the data resource of the cloned layer B.
 When B is opened in normal view, only valid properties are selectable to
 be mapped in Property Pane. Invalid ones already defined in XML are not.
 When B is saved it would be useful to get rid of all PropertyMapping
 previously defined in XML and to define only those that were checked in
 normal view (that are valid for the data resource).
 Not doing this leads to fdo errors FDO_81_IDENTIFIER_NOT_FOUND
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1898>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
