[mapguide-trac] #1896: Maestro layer validation incorrectly
report missing primary key
trac_mapguide at osgeo.org
Thu Dec 22 21:32:05 EST 2011
#1896: Maestro layer validation incorrectly report missing primary key
Reporter: gabrimonfa | Owner: jng
Type: defect | Status: new
Priority: low | Milestone:
Component: Maestro | Version: 2.2.0
Severity: trivial | Keywords:
External_id: |
Comment(by jng):
If you preview the Feature Source (the web-based one, not the Maestro one)
does it also fail to indicate identity properties (with a *) when you look
at the class definition?
If so, it's a problem with the FDO provider
If not, then yes this is a genuine defect
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1896#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
