[mapguide-trac] #1906: Maestro - Composite Line Editor SizeContext Units UI
MapGuide Open Source trac_mapguide at osgeo.org
Fri Dec 30 05:20:45 EST 2011
   Reporter:  crispinatime  |       Owner:  jng
       Type:  defect        |      Status:  new
   Priority:  medium        |   Milestone:  Maestro-4.1
  Component:  Maestro       |     Version:
   Severity:  trivial       |    Keywords:
External_id:                |
 When adding a new line to a composite line (that't the "Use composite
 lines" part of the classic linear feature style) the "Size Context"
 dropdown shows 'Device space' - however, what is actually stored in the
 XML is <SizeContext>MappingUnits</SizeContext>.
 This is very hard to spot when editing lines and, if left unedited results
 in apparently incorrect mapping and the legend does not render as
 expected.
 The workaround, once identified, is to either edit the XML or to set the
 composite line to Mapping Units, save and close, then re-edit changing the
 units back to Device space. Both are non-intuitive to the general user.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1906>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
