[mapguide-trac] #1594: Layer with EPSG:3398 CS not visible after publishing as WMS
MapGuide Open Source trac_mapguide at osgeo.org
Wed Feb 2 11:54:03 EST 2011
 Reporter:  liuar          |         Owner:  liuar
     Type:  defect         |        Status:  reopened
 Priority:  medium         |     Milestone:  2.3
Component:  WMS Interface  |       Version:  2.2.0
 Severity:  minor          |    Resolution:
 Keywords:                 |   External_id:  1383844
Changes (by brucedechant):
  * status:  closed => reopened
  * resolution:  fixed =>
  * milestone:  => 2.3
Comment:
 The attached fix needs to take into account that the underlying feature
 source may have more than one spatial context and the 1st one may not be
 the one you want. You need to use the SpatialContextAssociation related to
 the geometry property for the feature class you want in order to determine
 the specific spatial context of your data.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1594#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
