[mapguide-trac] #1597: Remove 16MB memory size restriction on
MgByte
trac_mapguide at osgeo.org
Fri Feb 4 19:02:09 EST 2011
#1597: Remove 16MB memory size restriction on MgByte
Reporter: brucedechant | Owner: brucedechant
Type: enhancement | Status: new
Priority: low | Milestone: 2.3
Component: General | Version: 2.2.0
Severity: trivial | Keywords:
External_id: |
Description changed by brucedechant:
Old description:
> With 64bit support and systems with more memory available today the
> original 16MB restriction on MgByte is no longer needed. Also in some
> cases this actually causes an error when theming on a large number of
> features because 16MB is not large enough to contain all of the data.
New description:
original 16MB restriction on !MgByte is no longer needed. Also in some
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1597#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
