[mapguide-trac] #1602: WFS GetFeature with Http post doesn't support GML2 output format
MapGuide Open Source trac_mapguide at osgeo.org
Tue Feb 15 21:32:39 EST 2011
   Reporter:  liuar    |       Owner:  liuar
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  2.3
  Component:  General  |     Version:  2.1.0
   Severity:  trivial  |    Keywords:
External_id:  1385974  |
 The output format parameter(GML2 and GML3) for !GetFeature request is not
 standard output format defined by OGC, which should be text/xml;
 subtype=gml/2.1.2 and text/xml; subtype=gml/3.1.1.
 For HTTP get, MapGuide translates the non-standalized parameter to
 standalized one by !ProcessArgumentAs() in !RequestParameter().
 It is also needed for HTTP post to translate these parameters
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1602>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
