#1746: Maestro .LayerDefinition - Display Composite Fail
Reporter: crispinatime | Owner: jng
Type: defect | Status: new
Priority: medium | Milestone: Maestro-3.5
Component: Maestro | Version:
Severity: minor | Keywords:
External_id: |
On any existing .LayerDefinition (schema v1.3), when I edit in Maestro 3.5
(build from \trunk) and click the new "Display Composite" checkbox I get
the following exception:
Assigned value does not implement ICompositeTypeStyle2
System.InvalidOperationException: Assigned value does not implement
at
OSGeo.MapGuide.ObjectModels.LayerDefinition_1_3_0.VectorScaleRangeType.set_CompositeStyle(ICompositeTypeStyle
value) in
e:\Projects\Maestro\OSGeo.MapGuide.MaestroAPI\ObjectModels\VectorLayerDefinitionImpl.cs:line
340
at
Maestro.Editors.LayerDefinition.Vector.Scales.VectorScaleRangeCtrl.chkComposite_CheckedChanged(Object
sender, EventArgs e) in
e:\Projects\Maestro\Maestro.Editors\LayerDefinition\Vector\Scales\VectorScaleRangeCtrl.cs:line
167
at System.Windows.Forms.CheckBox.OnCheckedChanged(EventArgs e)
at System.Windows.Forms.CheckBox.set_CheckState(CheckState value)
at System.Windows.Forms.CheckBox.OnClick(EventArgs e)
at System.Windows.Forms.CheckBox.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons
button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message&
m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg,
IntPtr wparam, IntPtr lparam)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1746>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
