[mapguide-trac] #1752: Misuse column name instead of column index during data reader's serialization
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jul 14 03:46:33 EDT 2011
serialization
   Reporter:  sparkliu         |       Owner:
       Type:  enhancement      |      Status:  new
   Priority:  low              |   Milestone:
  Component:  Feature Service  |     Version:
   Severity:  trivial          |    Keywords:
External_id:                   |
 During the serialization of data reader, most of code uses column name
 instead of column index, for example, get column type, check null, get
 data.
 Actually as the final purpose is to return the whole dataset, there is no
 such situation that a column exists in dataset but not serialized, also
 the sequence of property is exactly the same with the sequence of column.
 So the serialization can be optimized to use column index to reduce column
 searching.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1752>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
