[mapguide-trac] #1758: Selecting point features that have been
styled using fonts a reprojected layer linked
trac_mapguide at osgeo.org
Tue Jul 26 02:44:49 EDT 2011
#1758: Selecting point features that have been styled using fonts a reprojected
layer linked
Reporter: hubu | Owner: hubu
Type: defect | Status: new
Priority: medium | Milestone: 2.3
Component: Rendering Service | Version: 2.2.0
Severity: trivial | Keywords: Symbol
External_id: 1381956 |
Comment(by hubu):
This is a CS transform issue. In the step#4, if we don't change the cs of
the map, this issue will not happen.
The reason of this issue is in renderingforselection() function, the map
extent is not transformed to the cs of layer, there is not intersetion
between the map extent and the selection point, because they are not in
the same CS.
And there is another issue, when stylizeVectorLayer, we also need a
xformer, or else the LineBuffer and the selection point are not in the
same CS.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1758#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
