[mapguide-trac] #1451: Posible performance issue when parsing strings (Using StringBuilder instead string concatenate)
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jun 1 08:22:25 EDT 2011
string concatenate)
 Reporter:  sreckol                                       |         Owner:  jng
     Type:  defect                                        |        Status:  closed
 Priority:  high                                          |     Milestone:
Component:  Web API                                       |       Version:  2.2.0
 Severity:  major                                         |    Resolution:  fixed
 Keywords:  StringBuilder string concatenate performance  |   External_id:
Changes (by jng):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Fixed 2.2 (r5894)
 Fixed trunk (r5895)
 I have not applied the page directive changes. If you can cite some
 performance data proving solid performance gains with these directive
 changes, then re-open the ticket and I'll look at getting that in as well.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1451#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
