[mapguide-trac] #1726: Restructure Layer Style Editor
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jun 22 13:12:02 EDT 2011
   Reporter:  jng          |       Owner:  jng
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:  Maestro-3.5
  Component:  Maestro      |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
 The existing Maestro Layer Style editor is a woefully inefficient use of
 precious vertical screen real estate.
 Instead of rendering out each scale range as a separate control, we can
 compress this by displaying the scale range as a list. Selecting a scale
 range in this list will then create and load the corresponding UI control
 to edit the style rules in this scale range.
 This change is really to make the composite symbolization stuff easier to
 integrate.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1726>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
