[mapguide-trac] #1727: ENUMERATEDRAWINGLAYERS can return extra redundant layer names
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jun 23 12:21:07 EDT 2011
   Reporter:  jng              |       Owner:
       Type:  defect           |      Status:  new
   Priority:  low              |   Milestone:  2.3
  Component:  Drawing Service  |     Version:
   Severity:  minor            |    Keywords:
External_id:                   |
 Create a Drawing Source using the attached DWF in #1338
 Now call an ENUMERATEDRAWINGLAYERS operation on this Drawing Source using
 the section name that corresponds to the "Elmwood Park - RDC1 - Basement"
 sheet.
 The XML response contains many double ups of the same layers.
 Other sheets produce the same result.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1727>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
