[mapguide-trac] #1728: Fetch size is not set when using command
even when DataCacheSize configuration is set
trac_mapguide at osgeo.org
Mon Jun 27 21:29:24 EDT 2011
#1728: Fetch size is not set when using command even when DataCacheSize
Reporter: sparkliu | Owner:
Type: enhancement | Status: new
Priority: low | Milestone:
Component: Feature Service | Version:
Severity: trivial | Keywords:
External_id: |
When executing command (MgServerSelectFeatures or
MgServerFeatureService.ExecuteSqlQuery), if not specified, fetch size will
always be 0. However, as user has already set DataCacheSize, we should use
this size to avoid multiple fetch.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1728>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
