[mapguide-trac] #1736: Linux build scripts size-optimized for OSGeo
LiveDVD
trac_mapguide at osgeo.org
Thu Jun 30 22:16:12 EDT 2011
#1736: Linux build scripts size-optimized for OSGeo LiveDVD
Reporter: jng | Owner:
Type: task | Status: new
Priority: low | Milestone:
Component: Build System | Version: 2.2.0
Severity: trivial | Keywords:
External_id: |
With the OSGeo LiveDVD, disk space is a premium. There has been reports
from the LiveDVD mailing list about the relatively high disk space being
used by MapGuide. The bulk of this bloat is the CS-Map coordinate system
dictionaries.
I recently asked the question about slimming down the CS-Map distribution
and got this response from Norm Olsen:
Hello Jackie . . .
If trimming the size of the distribution is the big issue, please consider
the following:
To the best of my knowledge, MapGuide does not ever use any of the Geoid
Height functions within CS-MAP. Thus, all of the data files in the three
Geoid sub-directories of the Dictionaries/USA directory can be omitted
from the distribution. Also, the WW15MGH.GRD file can be removed from the
Dictionaries directory. Much of this data is in binary form and does not
compress down very well, so the distribution size reduction could be
significant.
Norm
For reference, that's these directories:
* CS-Map/Dictionaries/Usa/Geoid03
* CS-Map/Dictionaries/Usa/Geoid96
* CS-Map/Dictionaries/Usa/Geoid99
And these files:
* CS-Map/Dictionaries/WW15MGH.GRD
Creating a size-optimized version of the linux build scripts that omits
these directories and files will save up to 116mb on the LiveDVD.
If we are only going to showcase the Sheboygan dataset, this omission has
no negative effects and in fact we could even probably cut out more CS-Map
dictionary files and save even more space on the LiveDVD.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1736>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
