[mapguide-trac] #1593: Mapguide OEM install failing make check
	tests
    trac_mapguide at osgeo.org
    Thu Mar 10 09:23:14 EST 2011
#1593: Mapguide OEM install failing make check tests
   Reporter:  dbx2011       |       Owner:
       Type:  defect        |      Status:  new
   Priority:  low           |   Milestone:  2.3
  Component:  Build System  |     Version:  2.2.0
   Severity:  critical      |    Keywords:
External_id:                |
Changes (by trevorwekel):
  * milestone:  2.2 => 2.3
Comment:
 MdfTestMap.MapDefinition is only present in trunk.  Changing the milestone
 to 2.3.  Please note:  trunk is not a stable release branch.  Building and
 using "trunk" for a stable production environment is not recommended.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1593#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
